So far I have removed the raditor shroud, and drained the rad. I have removed the two rad. hoses. I'm tring to remove the harmonic balancer 15/16" bolt. I added a long pipe to my rachet but it won't lossen, i'm turning the bolt clockwise to loosen. Correct?? Will i need to barrow an air wrench to loosen this bolt? I got all the bolt loosen on the water pump, can I just lift the water pump straight up and out. Or do I need to loosen the ac compressor to?
The harmonic balancer bolt is better taken out with an impact, if you can hold the engine still you can undo it with a big breaker bar. When you get all the waterpump bolts out, yes it just comes off.
I ran a flat bar between two of the four bolts, that hold then the fan blades. Even with a breaker bar it won't loosen, it's clockwise right to loosen?
I always just put a pipe on the breaker bar, socket on the bolt, un-hook the coil wire, and used the starter to break the bolt loose. has worked on every Ford I've ever owned. Position the pipe/breaker bar either on the frame or angled to the ground. Probably not the smartest way to do it, but.......
