2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Good News...
Old May 19, 2008 | 12:54 PM
montecarlo31's Avatar
montecarlo31
Nice lookin truck. I'd dump those conti tracs, my boss had them on his and you could run over a McDonalds straw and put a hole in the side wall.
Take a pick of the door plate where it says GVW, WB, etc, and we can decode.
Old May 19, 2008 | 01:13 PM
berry1234's Avatar
berry1234
I know, has to be the worst tire ever. They are especially bad on the freeways around here with the paralell grooves cut into the road. Makes the truck feel like it's sliding left and right.
I will take a pic.
Old May 19, 2008 | 02:49 PM
berry1234's Avatar
berry1234
Here is the sticker. Sorry for the bad quality, I only have my cell phone working. Looks like axle code is 15?
Old May 19, 2008 | 03:31 PM
montecarlo31
3.31s. Mine reads 15 and it's 3.73s.
Old May 19, 2008 | 03:35 PM
montecarlo31
double checked and X15 (order code in glove box) is 3.31s.
Old May 21, 2008 | 05:44 PM
Tmod700's Avatar
Tmod700
My 2008 Expedition 4x4 has a axle code if 16 and we special ordered it with the 3.73 ratio.
Tmod
Old May 21, 2008 | 05:51 PM
berry1234's Avatar
berry1234
Ok, so what's the deal with 3.31 vs 3.73? I don't tow either.
Old May 21, 2008 | 06:41 PM
montecarlo31
3.31s slower, and if you go to bigger or heavier tires ever worse fuel economy.
Old May 21, 2008 | 08:43 PM
Tmod700's Avatar
Tmod700
If you don't tow and you have 3.31 you should be ok as you really wouldn't desire the 3.73s unless you wanted better acceleration.
You should get a little better MPG with the 3.31s as opposed to the 3.73s.
Tmod
expeditor's Avatar
expeditor
Beautiful truck berry i really like the woodgrain on the shifter.
Old May 27, 2008 | 04:48 PM
Baumbach's Avatar
Baumbach
How can I tell what ratio I have? Both my 07 and 08 had the tow package.
I talk about this on my website and have pictures too.
2008 Ford Expedition Limited
Old May 31, 2008 | 12:33 AM
poppie's Avatar
poppie
Originally Posted by SemperFiDevilDog
The 2008's (Non-EL) come Standard with the 3.31 Rear Axle
The 2007's (Non-EL) came Standard with the 3.73 Rear Axle
----------------Not so unless you have 4X4,our 4X2 2007 came standard with the 3:31 and that is what the book say's also.
Old May 31, 2008 | 12:49 AM
  #28
poppie's Avatar
poppie
I will take a pic.
----------------That's the truth, our 2007 expedtion eddie bower had a right rear sidewall blow out in town at 35 MPH with ONLY 26000 mile's on them ,alway's kept them at 44 PSI,that's the pressure on the sidewall,put Michlin LTX AS'S on and now find out the sidewall PSI is only 35 lb's,now I wonder if I screwed up buying them,how can the same size "light truck" (LTX) tire carry less air than the POS conti's ford put on???????.
Old Jun 1, 2008 | 11:58 AM
  #29
rich93cw's Avatar
rich93cw
Michelin LTX is not necessarily a "light truck" rated tire. Some are passenger car tires, with the size designation starting with Pxxx, and some are light truck with the tire size destignation starting with LTxxx. The Michelin LTX P tires are most often designed with a max. inflation pressure of 35 psi. and the LT tires are most often designed with a max. inflation pressure of 50 psi. If you look at two tires of the same xxx size, the P tire will have a higher load capacity than the LT tire regardless of that pressure difference, because the LT tires are derated for truck use according to the Tire and Rim Manufacturers Association and Federal Motor Vehicle Safety Standards for tires. The LT tires are heavier, and have thicker side walls so that they are more durable in truck driving situations such as construction sites, off and unimproved road use. Make sure that the load rating for the tire is higher than half the Gross Axle Weight Rating of your axle, and that the rim is rated for the maximum pressure that is listed on the tire sidewall.
Old Jun 1, 2008 | 12:34 PM
  #30
berry1234's Avatar
berry1234
The correct pressure is 35psi for those tires. Pressure is on the sticker on the drivers door frame.
