All cleaned up!!
Old May 9, 2008 | 05:13 PM
86Stepside's Avatar
86Stepside
All cleaned up!!
Well, I left work early and, I thought I should give the truck some attention. I washed it, and cleaned the interior.
Last summer I put on new doors and fenders to replace the old rusty ones. I also converted to power windows and locks.
Old May 9, 2008 | 06:26 PM
rmalottwtes30's Avatar
rmalottwtes30
Looks pretty dang nice...Whats with the hole above the glove compartment?
Old May 9, 2008 | 07:31 PM
86Stepside's Avatar
86Stepside
When I bought the truck it had some old thing that counted miles for trips, and i think it told your mpg if i remember right. I pulled it out shortly after, unfortunately thats where some p.o. put it, and I have a hole now.
Old May 9, 2008 | 08:56 PM
86F150302's Avatar
86F150302
How hard was it converting to power windows and locks? I am getting tired of leaning over the seat to roll down the passenger side window everyday. Also how much would it cost to convert?
Old May 9, 2008 | 11:35 PM
86Stepside's Avatar
86Stepside
It wasn't very hard to do. I replaced my doors, one had power windows/locks, the other didn't. I found another that did and took the wiring, window motor, lock actuator and put it on my door. There is a wiring harness that plugs in at both doors that runs along the firewall, and two wires goes to the fuse panel, if you unscrew the panel the wires will plug right in the corresponding spots. I was able to pull everything needed at the junkyard, for the motors and wiring on the doors you can use parts from newer trucks, but the wiring that goes from door to door the wires that go to the fuse panel have different plugs on 87-96 but the rest of it is the same.
Old May 9, 2008 | 11:42 PM
86F150302's Avatar
86F150302
ok thanks. Ill look into it.
kraylake
Nov 20, 2013 08:13 AM
Red Ford Truck
Ontario Chapter
39
Oct 26, 2012 06:36 PM
Mike's 77
137
May 1, 2008 06:32 AM
Snowking
21
Dec 1, 2007 07:56 AM
02superstroker
Aug 11, 2003 11:26 PM
