Moter Swap
Old May 9, 2008 | 07:58 AM
jed556's Avatar
jed556
Arrow Moter Swap
I have a 87 F-150 wat is needed to go from a 300 6 cyl to a 302 or 351?
the 6 is fuel injected with a 4 spd 2 whl drive
Thanks
Jed
Old May 9, 2008 | 08:24 AM
Conanski's Avatar
Conanski
You need a donor vehicle to pull the complete engine, wiring harness and computer from.
Old May 9, 2008 | 09:32 AM
haroldrussi's Avatar
haroldrussi
If you want to be fuel injected you will need to do as "Conanski" says but if you want to go to a carb. then you need less. Change the in tank fuel pump to a lower pressure unit and go to an old distributor and go for it.... Either way can be a lot of work for the in-experenced. Good luck....
