1978 - 1996 Big Bronco
identifying lift kit
Old May 8, 2008 | 11:25 PM
dave351m's Avatar
dave351m
ive got a 79 bronco and wandering if there was some identification numbers on the lift kit somewhere that could tell me what size it is. its a rugged trail brand,in the front it has radius arm drop brackets and panhard bar and coils, in the rear it has blocks and a wedge im guessing that is to correct the driveline angle the block measures 3in not counting the wedge. i put the motor and trans in and it has the rear driveshaft stretched to the limit and the front driveshaft is in a bind but i believe new some 4degree c bushings would fix that.
