How do I hook this back up?
Old May 8, 2008 | 10:10 PM
true blue's Avatar
true blue
A friend of mine has a 2006 F150 with a 5.4.
He lost vacuum to his brakes. I traced the line and it is loose from the intake. The problem is I can't get my hand on it. Where does it go? How does it install? Is there an easy way to access it?
Can anyone show me a picture of how it attaches?
Thanks
Old May 8, 2008 | 11:01 PM
VFR_Man's Avatar
VFR_Man
It's a SOB to get at. Someone just posted a few days ago about this, and they ended up taking it to the dealer, something about having to remove the intake manifold or something painful like that.
Found it, he said they removed the injectors: https://www.ford-trucks.com/forums/7...-4-vacuum.html
Old May 9, 2008 | 07:05 AM
true blue's Avatar
true blue
Great.......
I appreciate the info.
Old May 9, 2008 | 10:15 PM
true blue's Avatar
true blue
I cannot believe no one else has been faced with this to give some additional advice. Once I figure out how to do this I will pass the information on.
Old May 10, 2008 | 02:19 PM
FatalErrorz's Avatar
FatalErrorz
A buddy of mine had his do the same thing, on an 06. He pulled the intake to get it back on, then clamped it so it will never come off, added a tee so he could disconnect it if needed and rerouted the thing. He says it was a major PITA.
Old May 10, 2008 | 10:36 PM
true blue's Avatar
true blue
Brake booster vacuum line back on!
Well I got it on without removing the intake. I did not put a clamp on it but it needs one. I will work on it more latter but for now it is up and running.
The problem is that every once in a while the truck does not start right away. Being used to the truck starting with a tap on the key means it does not make a full revolution and the motor sort of sneezes. Since this line is designed to function under vacuum Ford did not prepare for a possible pressure situation.
And yes, this job was a PITA!
Ford, you need to put a clamp on this darn line!
Old May 11, 2008 | 11:11 AM
Golflug's Avatar
Golflug
what all did you have to do to get the line on?, Remove injectors, manifold etc?
Old May 11, 2008 | 12:15 PM
true blue's Avatar
true blue
I removed the air filter box and the throttle body just to give me room. I did not remove the fuel injector rail. I did flex the fuel line forward so I could get my hand back there. I also disconnected the T fitting and the rest of the vacuum line from the brake booster to make the line easier to maneuver.
I looked at the line and nipple with a mirror and then did the work by Braille knowing in my head how it had to go back on. Once I got the line on the nipple it slid on very easily; too easily. This was not comfortable as you have to lie on top of the engine.
I am going to use some aircraft grade wax string that is used to secure wires on aircraft, to secure the vacuum line. I will tie onto the line where the elbow is and run the string forward under the intake and tie it off somewhere accessible. This should keep the line from blowing off in the future. The string will not cut into the intake or line and should last for 20-30 years.
Old May 11, 2008 | 12:44 PM
Golflug's Avatar
Golflug
great information, This will help many. Hopefully I will not need to use it.
Old May 16, 2008 | 11:45 AM
true blue's Avatar
true blue
Recall!
Figures; after I cut myself up on this they release a recall 4 days latter.
Old May 16, 2008 | 12:07 PM
cdestuck's Avatar
cdestuck
They must have seen that you got yours done and figured one less for them to repair!
