Sponsored by: Kumho
PowerSlot & Hawk initial break-in question
Old May 8, 2008 | 09:52 PM
71-4R3SONS's Avatar
71-4R3SONS
<TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>Hey Guys...
I took the day off today to install my Cryo PowerSlots and Hawk LTS pads...
Biggest problem was getting the rear rotors off... handy BFH worked just fine.
I want to make sure I did the initial break-in correctly... Here's what I did:
1. Drove around for 25 miles using the brakes every "once and a while"... very light pressure.
2. I did ten 30mph to 5mph moderate braking "almost stops"... between each almost stop I drove for 2-3 minutes to cool the brakes.
3. Then I did three 60mph to 5mph, heavy on the pedal, "almost stops"... between each almost stop I drove 3 minutes to cool the brakes.
4. Repeated #2 then #3. Drove 10 minutes home without using the brakes to really cool them well.
5. Parked the X and checked the rotors for heat (hardly any).
Well guys... this is how I interpreted the instruction from PowerSlot...
Did I do it right?
A few years ago I installed front ART cryo rotors w/Performance Friction pads on my old 99F250SD/SC... the initial break-in was much more agressive... I remember smoking the OEM rear brakes while doing the "almost stops"... Plus I remember smelling the brakes too... something that the directions said would happen. Why such a difference in the initial break-in procedure??
Well, another mod is done ... this weekend I'll hit the barn for another mod!!!
</TD></TR></TBODY></TABLE>
