Alternator overcharging!!!
Old May 14, 2008 | 07:29 AM
fordtrck1955's Avatar
fordtrck1955
Well, got my parts guy to warranty out another new regulator, and still the same problem. Just didn't have time to get into the wiring last night again. Hopefully tonight though. Maybe I'll find something in that harness shorted together and fix this thing. I'll post what I find once again. Thanks, Brian
Old Oct 26, 2009 | 10:14 PM
overlandexpress's Avatar
overlandexpress
HEY.... fordtrck1955, if you find out the problem could you let me know? I am having the exact same problem, all I did was install a voltage gauge and all of a sudden I am running 14.5 at idle and as soon as you give it gas it jumps up to a solid 17.5 volts and stays there, thought I screwed something up and burned up the voltage regulator so I installed a new one and it does the same thing, it was a 35 mile trip home from work and I was sweating it all the way home! I do feel it has something to do with not having a good ground and bought a new engine block to fire wall ground strap, if i figure it out before you I will let you know the problem!
Old Oct 26, 2009 | 10:18 PM
overlandexpress
Just noticed the last post was may of 2008, Sure hope you found the issue by now if anyone has a clue though let me know!
Country_boy_2007
Dec 25, 2013 01:46 AM
paoilguy
Nov 17, 2013 10:31 AM
kpc3my
Sep 11, 2013 04:06 AM
Tom92F150
24
Aug 31, 2010 08:29 PM
