292 Fan blade question
Old May 7, 2008 | 10:13 PM
vbarker's Avatar
vbarker
I put a mustang radiator in my 58 f100 with the stock 292. The stock fan is a 4 blade 9 1/2". Question is; is there a smaller 4 or 5 blade fan that I can use to miss the lower radiator hose. If not I will have to lower the radiator a little. Thanks in advance
Vern
Old May 8, 2008 | 10:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Vern
1957/60 F100/350: The original fan is either 4 or 5 blades, 18 1/2" in diameter.
There is no fan for any Ford truck (or car) made after 1952 that's 9 1/2" in diameter - none.
Smallest car fan blade: 4 blade / 15 1/16" diameter = 1960/69 Falcon 6 cylinder / 1965/70 Mustang 6 cylinder.
Old May 8, 2008 | 01:33 PM
RCA78SS's Avatar
RCA78SS
fan
I think Vern is saying the radius is 9-1/2" which makes the diameter 19".
I'm pretty sure the car Y-block fans are the same diameter. Either trim the tips (hard to get equal & same balance), lower the radiator or buy an aftermarket flex-fan.
Good luck
Old May 8, 2008 | 04:01 PM
vbarker's Avatar
vbarker
RCA,, You are correct, Thanks for keeping me honest. I will check into an aftermarket and see what I can come up with.
Old May 8, 2008 | 06:29 PM
Sam_Fear's Avatar
Sam_Fear
Can't imagine those being too hard to find.
24
Jun 26, 2018 09:47 AM
Christopher Layton
Oct 21, 2015 10:32 PM
tractormanbill
Feb 28, 2014 04:37 PM
Derfus
May 28, 2012 01:22 AM
DGMFORD
19
Mar 14, 2006 08:25 PM
