Speaker instalation help
Old May 7, 2008 | 08:10 PM
Louie3's Avatar
Louie3
Well today I went ahead and upgaded my current rear speakers to 6x9 Sony Xplod 290w speakers. I opened up the rear speaker slot thing and when I tried to fit the speaker it did not fit? I was told 6x9" speakers will fit in the rear. Is it just me or is there a way to jig it into position
Old May 7, 2008 | 08:18 PM
95F350XL's Avatar
95F350XL
I think my backs were 5x9. I think you have to make the hole bigger if you want the 6x9 to fit.
Old May 7, 2008 | 08:25 PM
Louie3's Avatar
Louie3
I really hope I dont have to do that. I'm looking at all the info I can find about the model but none tell me about speaker size except for BestBuy
Old May 7, 2008 | 08:39 PM
86F150302's Avatar
86F150302
Crutchfield says you need 6x8s
Find Car Audio/Video Gear that Fits Your Vehicle at Crutchfield!
Old May 7, 2008 | 10:39 PM
football3295's Avatar
football3295
its no big deal just cut it out a little bigger for them to fit.
Old May 8, 2008 | 12:21 AM
Bluebomber94's Avatar
Bluebomber94
Not sure what year your truck is but my 97 took 5x7 in the rear.
Old May 8, 2008 | 09:45 AM
TexasGuy001's Avatar
TexasGuy001
It should be 5x7.
Old May 8, 2008 | 01:54 PM
jimbo beam's Avatar
jimbo beam
Emilie is you're truck a regular cab or an extended cab? My 96 F150 extended cab had 6x8s in the rear. I believe the regular cabs, at least some of them, left the factory with smaller 5x7s in the rear.
Someone correct me if I'm wrong but I believe trucks originally equipped with Ford premium sound systems used the bigger 6x8s, while trucks with the standard system had the smaller 5x7s.
I was able to retrofit a set if 6x9s in the back of mine. I used the original 2 top speaker mounting holes and I had to drill 2 new holes for the bottom. I wire tied a thick piece of foam to the back side of each rear speaker over the big magnet, otherwise the speakers would clank around against the inside metal of the truck.
If you're unable to fit the speakers inside the factory holes you could always get a set of 6x9 speaker boxes and mount them elsewhere.
Old May 21, 2008 | 12:39 PM
Louie3's Avatar
Louie3
yeah shes a regular cab. I was able to get a hold of the speakers and install them. But now I have a new question.
How do I remove the grille off of the door where the front speakers go
Old May 21, 2008 | 01:24 PM
jjstanza's Avatar
jjstanza
Remove the door panel to get to the door speakers.
Old May 21, 2008 | 01:56 PM
Dukernc's Avatar
Dukernc
Hey Louie3,
Check out the Interior & Exterior FAQ at the top of the SD forum to see if it has instructions on how to remove the door panel. There may be a link with pics that could show you how to remove the front door panel. I usually go there before asking just to check it out. Hope this helps. Good Luck!
