Sponsored by: Real Truck
Adding 2" to 6" lift
Old May 7, 2008 | 05:52 PM
05kingranchfx4's Avatar
05kingranchfx4
I have a 2005 F250 with a 6" pro comp lift. I have the stock track bar with the drop bracket. If I were to add 2" spacers to this lift what else would I need to get? The truck never leaves pavement. I think the shocks probably have enough travel in them...Im mostly concerned about the geometry involved with the front end....alignment, track bar, and steering.
Old May 7, 2008 | 09:29 PM
jello's Avatar
jello
Procomp makes offset bushings for the trac bar but you end up with smaller bolts through the bushings. You could also get an adjustable bar.
Old May 19, 2008 | 10:08 AM
05kingranchfx4
Im assuming that my drop pitman arm and radius arm bracketry will still all be ok? All ill need is an extended track bar up front, coil spacers, and 2" more lift out back? I have room for more shim in the driveshaft if necessary also.
