Cab interchange
Old May 7, 2008 | 03:04 PM
northernwheeler's Avatar
northernwheeler
Cab interchange
I have a 1985 F-250 4x4, 429, 4speed Lariet Reg cab I had put together about 10 years ago and stopped driving 6 years ago and put it in the corner of my shop. I recently got looking at it as I figured I would put some fresh gas in it, change the oils, shine it up and put a few miles on it.
The problem I am having is that I had put a Lariet interior in it years ago, and becuase of the carpet my rust free cab now has rust on the floorboards, and bad enough that it would be very difficult to replace just the bad floor.
I would like to know if any of the later years cabs (87 and up) will interchange, as rust free one are easier to find, and what kind of problems I might have in mounting a later cab to an 80-86 truck. I would really like to keep the 85 interior and accessories.
Thanks - Kurtis
Old May 7, 2008 | 03:29 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
87-96 should work fine for you.
The Firewalls are slightly different depending on year. You may have to make holes, or seal holes up for things like wiring harness, changes etc.
And of course the dash is different, you may have to modify where the 1980-1986 dash bolts to the cab of a 1987 or newer cab. I have seen cabs though with mounting holes for BOTH types of dashes after 1987 etc.
nothing else that comes to mind...
Let's just say it will be less work than trying to replace the entire floor, for sure.
Old May 8, 2008 | 11:08 AM
northernwheeler
Just what I wanted to hear. Thanks, now i can start looking for a good cab.
Old May 8, 2008 | 12:44 PM
uncle.stosh's Avatar
uncle.stosh
The front fenders bolt up differently also.
The bolt near the lower front corner of the door attaches differently.
Old May 8, 2008 | 05:13 PM
northernwheeler
Ok, I will have to check it out and see how different it is. I should be able to modify it if it isn't too different, should still be easier than tryingto repair the old cab.
Old May 8, 2008 | 05:44 PM
81-F-150-Explorer
It's not too different. A bracket, and/or a drill hole should solve the fender problem.
79fordchick
19
Mar 22, 2011 03:08 PM
c.l.nye
16
Dec 12, 2009 12:51 PM
turboboost
Nov 4, 2009 03:47 PM
ralf
Mar 21, 2007 01:26 PM
Sting2112
Apr 18, 2003 10:37 AM
