Here's my interior. Everything was poo-brown before with a rubber floor mat. Swapped jump seats out for a customized bench fitting a 12" sub, amp and 6x9s. The amp is under the center cushion, and I even put some fans in there that circulate air into the amp compartment when the amp is turned on.
No offense to Jeff but...anyway to add a spell checker to internet forums? Spelling and grammar mistakes just get under my skin...go figure with the Accounting as well as the finance degrees. Anyways, Interior is almost done...I'll show you pics of that a couple weeks after the engine is done.
ANYWAY is actually two words in that context, as in any way. Isn't irony fun?
Whoa! Hey flcracker9 did it take much to fit those 2003 F150 seats in??? They look nice, plus you get shoulder belts! My 74 has the ol bench with lap belts, and I want shoulder belts bad, thats a damn good idea!
Thanks for the compliments guys. It took a little ingenuity to get them in, some trimming of the power seat brackets (they sat too high in the cab), and I fabbed some L-brackets and welded them to the seats, bolted them in, hooked up a hot wire and a ground, and presto, power seats (driver only)back & forth, up and down, and tilt (lumbar is manual). The best 2 things are the integrated shoulder belts, and the ride quality is amazing compared to my old bench.
Thanks
