wheel size?
Old May 7, 2008 | 11:16 AM
michaelmoo's Avatar
michaelmoo
wheel size?
I have a 73 F100 2wd and have found a set of wheels that are 5*5.5 bolt and are 15" x 8.5: with back spacing of 3.75". Will these work on the truck or stick out to far?This is a Home Depot/Lowes/dump/crap hauler so it isn't a show truck. But i do want it to look ok. What size tire would you run on the above wheel?Mike
Old May 7, 2008 | 11:35 AM
scottie2hottie's Avatar
scottie2hottie
you should be ok with those wheels, being that they are only 8.5 wide. go for a 29 or 30 inch tall tire. Looks good even on 2wd trucks, and 31s are a hair too big, at least on my 76 2wd they were.
Old May 7, 2008 | 03:05 PM
duste's Avatar
duste
Wheels should be fine but a little wide, stock was aroound 6 inches +/-. they came with 235/75/15's but that tire would be to narrow for 8.5's. I run 8.5's and use a 275/60/15 and they look great. JMO
Old May 7, 2008 | 03:07 PM
SuperSnake's Avatar
SuperSnake
Check my 76 F250 Gallery if you wand to see 2wd with 33's
Old May 8, 2008 | 09:20 AM
michaelmoo's Avatar
michaelmoo
Thanks!!
I also have found a new set that are 7" wide. Would these be a better fit? Or should I go with the used 8.5"? If i go with the 7", what tire size would be the best?
Mike
Old May 8, 2008 | 10:00 AM
offroadbronco's Avatar
offroadbronco
With a 8.5" rim I'd put a little wider tire on it to fill the wheel well out, like a 31x10.5, the same tire would fit on the 7" rim but would be a little bit taller. Either rim will work.
Old May 8, 2008 | 12:54 PM
NOCO77's Avatar
NOCO77
Just my opinion, but on a 2wd, I like the stance of 8.5" with the 275/60-15 rubber - and you'll be very near the stock diameter (within 7/8") so speedo will be close and power will feel the same. 255/70-15 would also work well on the 8.5" and give you a little more diam (~29"). I guess it all depends on the look you want - street or off-road. If off-road, go with the 10.50/31 or 9.50/30.
