Broken Shift collar
Old May 6, 2008 | 04:16 PM
74F2504by4's Avatar
74F2504by4
Exclamation Broken Shift collar
Hello,
Truck info, 1974 F-250 Highboy 4x4, Auto. The column shift is broken, won't lock into place or shift into any gears. Took the steering wheel off, discovered the shift collar's center assembly(slides over the tube inside the column) was actually coming apart. Problem is when I took the shift collar off the tube came out with it. Not sure how to put it back together. Would it be better just to remove the column and get one from a junkyard or something? Or if anyone has experience putting it back together I would greatly appreciate your help. Thanks,
Patrick
Old May 6, 2008 | 05:10 PM
flathead95hp's Avatar
flathead95hp
Originally Posted by 74F2504by4
Hello,
Patrick
Patrick, the same thing happened to me after I got mine. I just put a used column in mine. The only thing is that you cant use a 2wd column unless you change the center shaft. Also, you can use a column up til 77, after that they moved the NSS to the trans instead of being on the column. Hope it helps.
