Header fitting
Old May 6, 2008 | 02:30 PM
77-250's Avatar
77-250
Header fitting
Can someone recommend a set of headers that will fit my 2wd 77 F250 with a 351M? I was looking at Dynomax # 85051. BTW, the truck is a 4 speed manual.
Old May 6, 2008 | 03:39 PM
Jodell's Avatar
Jodell
I just put on a set of hooker headers that I got off summit for $199. They went in pretty easy on my 78 F250 2wd with 400/C6. I had to bend the brake line on the proportioning valve and the header sits on the crossmember on the drivers side, but that does not seem to be an issue. I do have to work on the clearance on the passanger side around the tranny cooler lines and the front corner of the tranny pan. Not sure about fitment around a manual tranny, but I think they are narrower, so it may be easier.
Old May 6, 2008 | 05:56 PM
highboy1975's Avatar
highboy1975
dougs headers, mocked them up on the 360, they fit great. they claim fit gauranteed. summit sells them. mine are fenderwell exit. pricey though.
