Do our trucks learn, or not??
Old May 5, 2008 | 09:10 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Originally Posted by clux
I agree with the no learning crowd, I've never seen anything that indicated the pcm stores any data except for trouble codes.
Hmmm. Come to think of it, I have not either. I guess Jody has no idea what he is talking about since I have not seen it.
Now I highly doubt this. I have not seen gravity either. I think what we have to define here is what we will call "adaptive" and "learning".
To respond to the gauge wh**e, by your definition, no vehicle will adapt. They all will have some sort of look up table values for any sensor and a left and right limit. If not, they could learn their way to 10,000HP or blow themselves up.
I will grant that the more modern systems have looser, more robust systems, but still parameters. Your basic if-then.
So are we saying that the 7.3 has one table that is fairly rigid? After all, if there is no adjusting, then there is no need for an algorithm.
Old May 5, 2008 | 09:41 PM
clux's Avatar
clux
I don't know what incited the hostility, I'm just weighing in on the subject, Tenn. What I meant to say is that I have read and heard that our pcm's are not adaptive from sources that I respect just as much as you obviously respect Jody.
The thing that people seem to be have trouble understanding is that using an algorithm or if-then is not learning. The adaptive strategy pcms store data read from the sensors for a given set of conditions, and use that data to make a "decision" the next time. Our pcm's use the data from the various sensors to look at rigid data stored in the pcm or on a chip, and make a "decision". They don't ever look at "what happened last time" and adjust their "decision" accordingly. For a given set of parameters (input from the sensors), the same thing happens every time, which is coincidentally just how gravity works.
By the way, I'm not saying anything about Jody's knowledge, but I suspect his statement might be misunderstood. Jody has an account here, perhaps he can be enticed to weigh in and speak for himself?
Old May 5, 2008 | 09:43 PM
GEugeneS's Avatar
GEugeneS
Didn't someone say a clogged EBP tube would lower mileage (as well as the ULSD fuel)
Old May 5, 2008 | 09:50 PM
joegebff's Avatar
joegebff
Gone Fishin for Mark
It's true...uummm hummm. Tranny end too.
Old May 5, 2008 | 10:00 PM
bdrummonds's Avatar
bdrummonds
I dont believe this is correct either.
Challenge: Hook up to a large load and take a 100 mile trip. shut off truck unhook trailer, and go for a drive. Your truck will run stronger for the first few miles until it has had a chance resample all sensors and adjust to the load(or lack of) Now this may not be "learning", but it is storing and utilizing information from the previous run session.
Tenn01PSD350
I don't know what incited the hostility, I'm just weighing in on the subject, Tenn. What I meant to say is that I have read and heard that our pcm's are not adaptive from sources that I respect just as much as you obviously respect Jody. Did not mean to go on the attack. Sorry clux.
The thing that people seem to be have trouble understanding is that using an algorithm or if-then is not learning. The adaptive strategy pcms store data read from the sensors for a given set of conditions, and use that data to make a "decision" the next time. Our pcm's use the data from the various sensors to look at rigid data stored in the pcm or on a chip, and make a "decision". They don't ever look at "what happened last time" and adjust their "decision" accordingly. This applies to all vehicles, it is still an algorithm. It can remember all it wants but still has to operate within parameters no matter what.For a given set of parameters (input from the sensors), the same thing happens every time, which is coincidentally just how gravity works. We will leave gravity out for now because I have a beef with it.
I will try to quote him as best I can recall: "I hear that a lot, the 7.3 does not have ability to learn. This is not true".
I suppose what is in question is the extent of learning, and how we will define it. I don't think we will ever get the full answer here as that is an industry secret still, to this day.
Old May 5, 2008 | 10:41 PM
clux's Avatar
clux
I have never had the experienced what you describe with my pickup. My towing is typically my horse trailer, tack, and 4 horses, the ranch where we summer cattle is 100 miles away, there's about a 2 mile fairly straight run in there that exceeds 7% grade. A lot of times when we get to the ranch I will unhook from the trailer to drive into the hills. I do not notice any difference in the way it drives then than when I have run it empty for 10,000 miles. It's the same truck, it shifts the same, it accelerates the same. It does behave differently when I flip through my programs, though.
Old May 5, 2008 | 11:20 PM
clux's Avatar
clux
Nope, not the transmission either. The 5r110 does however, and that's why there is a relearn procedure for it if the batteries are disconnected:
Torqushift Shift Relearning Strategy
TorqShift Harsh/Slipping Engagements, Upshifts, and/or Downshifts:
If these symptoms are experienced after the batteries have been disconnected, then it is due to the transmission adaptive strategy being cleared from the computer. This may occur when the vehicle is delivered new from the factory as well.
1. Warm the engine and transmission to operating temperature with all accessories off.
2. Idle engine for one minute with engine warm and all accessories off.
3. Idle engine for one minute with A/C on.
Then:
1. While driving, perform three series of upshifts at light, medium and heavy throttle.
2. While stopped, perform three sets of gear engagements (N-R, N-D, D-R, R-D) with the brake pedal firmly depressed and waiting three seconds between each engagement.
Perform these steps once in normal mode and once in tow/haul.
Old May 6, 2008 | 05:10 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by piotrsko
what do you call modifing the LT & ST fuel trims? Mine didn't get to -38 after a reset all by itself.
When my brother drives it for a week, the LTFT goes back to about +10 or so then my mileage stinks for about a month. When my wife drives it, LTFT goes to -15.
How else does Limp mode function? the PCM HAS to know that some sensors have failed and modifies what it can to keep running, if possible
There may not be LOTS of adaptive learning, but it has more than a calculator
Fuel trim on a diesel engine?
That sort of programming is for a gas engine where fuel ratios must be maintained at 14.7:1.
Old May 6, 2008 | 05:56 AM
JOE-M's Avatar
JOE-M
Yep. When I was running stock tuning I would notice this all the time. I always wanted it to keep running like this but it would go away after 30 minutes to an hour. Running the tuner now it doesn't do it anymore (at least you don't notice it).
Joe
Old May 6, 2008 | 07:00 PM
CSIPSD's Avatar
CSIPSD
Your seat of the pants meter is whats telling you your truck is running stronger, otherwise everyone would pull a trailer to the dyno...
Come on people, there is a differance from a response then looking back atpast history and changing something "because this happened last time"
The 7.3 DOES NOT have any ablity to look back at past experances or issues. It is a here and now type of computer.
The 7.3 has NO adaptive stradigy.
Old May 6, 2008 | 07:15 PM
That_Guy's Avatar
That_Guy
Ive never had this happen, might "feel" stronger because you were pulling a load and the truck would acclerate slower than without the load so when you take the load off you think or "feel" it taking off faster when really you were just used to the load being there and the truck was accelerating slower because of that. Just my .02 cents, If it even makes sense.
Old May 7, 2008 | 07:53 PM
  #28
MisterCMK's Avatar
MisterCMK
Now I am somewhat of a diesel n00b but I had to raise a brow when he said that. With a gasser you have fuel trims but I didn't think that there were the ST and LT trims on a diesel.
That is what I am thinking. I know that my truck feels like a racecar when I unhook the trailer from it.
Old May 7, 2008 | 08:30 PM
  #29
Tenn01PSD350
We have beaten this horse before here. There is no need to abuse trigger any further. Minds are made up, and nothing will change that.
Without proof this is all hot air and argument. Therefore we should let this go.
So, Joe the TN N** Swinger is wrong.
Old May 8, 2008 | 05:19 AM
  #30
just another truck's Avatar
just another truck
Ok, sorry for beating the horse...SO what about that 6637.. Truthfully thought, it was not intention to drag this throught he mud.. it was strictly brought on my driving expereince, and th e action I had taken just before leaving... Thanks all for your responses..
