Valley pan trouble
Old May 5, 2008 | 10:26 AM
56efffie's Avatar
56efffie
Valley pan trouble
Is it true you have to remove the timing cover to get the Valley pan off? I removed my intake but the pan doesn't clear the heads. I didn't want to remove the timing cover am I doing something wrong?
Old May 5, 2008 | 12:13 PM
THX1138-Z's Avatar
THX1138-Z
The stock valley cover will tilt enough to clear the ports at the heads once the intake is removed. Timing cover does not need to come off. One of those aftermarket aluminum covers will be iffy if it hasn't been notched to clear the intake ports at the heads though.
Old May 5, 2008 | 07:14 PM
56efffie's Avatar
56efffie
The cover is stock but does not clear the heads even with the cutouts.
Old May 5, 2008 | 10:00 PM
vbarker's Avatar
vbarker
56effie,,, you may have to use a small screwdriver or something to pry the valley cover over and pop it up past the intake ports. Don't worry you won't break anything. It's a snug fit but it will come out
Old May 6, 2008 | 08:56 AM
56efffie's Avatar
56efffie
Thanks for the help, I will try to gently pry it past the head.
Macrobb
18
Feb 17, 2016 11:23 AM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Jan 6, 2015 01:51 AM
Dodge/Cummins
Mar 7, 2013 10:46 PM
patmedic
Jan 24, 2011 12:23 PM
54-66F100man
Dec 29, 2009 12:59 PM
