Sponsored by: Auxito
No spark!
Old Aug 26, 2001 | 09:16 AM
Grinch's Avatar
Grinch
No spark!
[font size="1" color="#FF0000"]LAST EDITED ON 26-Aug-01 AT 10:28 AM (EST)[/font][p]I have a 1997 F-350 4x4 with a 351 engine and EEC IV eletronic ignition. I have no spark at the coil's high tension lead. I have 12v. going into the primary side of the coil and 12v. coming out of the negative side of the coil. I looked up in a Chilton's manual the troubleshooting procedures for the coil, (by the way I checked the coil against a friends truck and we got spark) PIP (Profile Ign. Pickup) and the ICM (Ignition Control Module). The Manual says to change the PIP or the ICM if you don't get a flashing signal from a twelve volt test light (when you put it into the negative side of the coil with the ignition key to the "run" position and cranking the engine) to ground. I changed both components without any luck. Has anyone had similar problems? Any advice would be greatly appreciated.
Thanks.
Old Aug 26, 2001 | 09:07 PM
Ultramagdan's Avatar
Ultramagdan
No spark!
Ghosttowner
18
Dec 23, 2014 09:37 PM
devbravo
Dec 31, 2013 08:48 AM
mudder_lover
29
May 4, 2011 08:59 PM
g_k50
1978 - 1996 Big Bronco
21
Oct 11, 2008 07:48 PM
