Rear Leaf Spring Question
Old May 5, 2008 | 04:52 AM
TexasGuy001's Avatar
TexasGuy001
Smile Rear Leaf Spring Question
I have a couple questions about rear leaf springs. My truck is a 2wd with spring code G so it has the slightly heavier duty rear springs. I looked at NPD and LMC and the light duty springs are 134.95. Why are mine 524.95. That is just rediculous! Why is the price so much more?
Also, I was thinking about swapping out all 4 front and rear springs on my truck with 1st Gen Lightning springs. I can get a nice set for 150 bucks! I just read that the payload for a 1st Gen Lightning is only 745 pounds. The regular 2wd trucks have either 1410 pounds or 2205 pounds. Is the reason for this more the tires than anything or are the springs really that soft. I thought they were stiffer. I just thought it would be cool if my truck sat a little lower and handled better. If the payload is really reduced that much I probably won't do it. I can't decide. If I don't swap out the springs, I would like to get the the lower traction bar leaf with the rubber snubber on the end that the Lightnings have. Does anyone know where I can get this?
