Seat swap
Old May 5, 2008 | 12:08 AM
65f100_352's Avatar
65f100_352
Seat swap
I got one probably dumb question, would a later model seat bolt in my 65? I just got a seat out of a 91 F150 and it bolted into my 78. Would something like this work in a slick?
Old May 5, 2008 | 12:55 AM
camperspecial65's Avatar
camperspecial65
I wasnt sure initially about the 91 to a 65...fuzzy memory a bit...but I know w/o a shadow of doubt a bench seat from a 78 is a direct bolt in into a 65...
- cs65
Old May 5, 2008 | 01:18 AM
65f100_352's Avatar
65f100_352
The 91 seat in my 78 now is a direct bolt in. Just had to swap over the slider brackets. It sits a little farther forward than the original, maybe a 1/2 inch, but not enough to worry about. I was more worried about if the slider bracket would go on the newer seat and also would the seat be too wide? I ask because my 65 seat is in no too good of shape. Thanks!
Old May 5, 2008 | 05:13 AM
jowilker's Avatar
jowilker
The 78 & 65 share the same floor pan, it will be a direct bolt in from the 78.
If you have arm rests you will have to open the door to tilt the seat back forward, but the seat will fit.
John
