Sponsored by: Real Truck
foil delete intercooler removal trouble
Old May 4, 2008 | 12:25 PM
sfgiantsfan9's Avatar
sfgiantsfan9
Yesterday I had 45 minutes in between work time so i decided to take off my intercooler pipe to get remove the foil. I took the front clamp off the top and the front clamp off the bottom. I tried to work it out of the two pieces of hose but had no luck. I ran out of time before i could get it. Is there any tips you guys can give me on how to get the pipe out of there? Thanks for the help
Old May 4, 2008 | 12:39 PM
rbaker6336's Avatar
rbaker6336
unlees someone has put some sealer on the boots it normally comes out pretty easy,take top loose first then work the bottom of
there's normally enough oil on them to slide off easy
Old May 4, 2008 | 12:51 PM
sfgiantsfan9
Do i have to take off all four clamps or do i only need to take off the front two?
Old May 4, 2008 | 12:55 PM
rbaker6336's Avatar
rbaker6336
should only have to take the rear one off,you might try taking a small screw driver and carfully work the boot loose from inside
Old May 4, 2008 | 12:57 PM
sfgiantsfan9
So the whole boot has to come off? i was trying to remove the pipe from the boot and leave the boot attached
Old May 4, 2008 | 01:03 PM
big poppa's Avatar
big poppa
I took mine out as well. They stick alittle, so get a flathead screw driver and go under the lip of the boot very gently like you were cleaning your toe nails(euhh). You get the idea. I left the boots on just slid the tube out. Good luck.
