Little help.........
Old May 3, 2008 | 02:11 PM
jorgholio's Avatar
jorgholio
Hi, wondering if anyone on board knows where a good place to buy new cyl head bolts 4 my 51 239 Flathead? I could use old ones if I had to. Nice to have new, I cleaned up block and threads were not perfect, new bolts would be sweet! Thankssssssssss
Old May 3, 2008 | 03:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Try a websearch; I've seen this discussed and I think they are available, but are pretty pricey and I don't remember who had them. ARP? also check eBay, Speedway, and JobLot. There may even be NOS bolts still around. You could always go to studs. Henry's originals were mighty well made, I'd try for OEM.
Old May 3, 2008 | 08:14 PM
rcav8or's Avatar
rcav8or
If you use it, SUPPORT IT
Flathead Jack has studs and nuts, not sure about bolts...
Flathead Jack studs
JobLot would be another one I'd recommend contacting, also.
R
Old May 3, 2008 | 08:20 PM
gdgerland's Avatar
gdgerland
Vern, If you can live with used ones, I have seen them several times on E-bay.
Gil
Old May 3, 2008 | 09:34 PM
Bob at warsaw's Avatar
Bob at warsaw
Go back with studs and nuts, not bolts
Old May 3, 2008 | 10:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Flatty heads with studs seem to have a fair amount of trouble with water leakage around the studs. Worse with aluminum heads, but it's a common enough problem to make bolts look more attractive IMO.
Old May 4, 2008 | 09:28 AM
Kusto's Avatar
Kusto
Did you try George Moir's? Maybe you want some bolts with some bling? Totally Stainless may have a complete stainless dressup bolt kit for your engine. Also maybe give the Old Car Centre in Langley, BC a call.
Old May 4, 2008 | 05:43 PM
jorgholio's Avatar
jorgholio
thanks everyone.........
Found some, at LMC. Shipping might cost me my first born but they are coming. Thanks again. Missed the swap meet in red deer due to important commitments, did anyone make it?
