freez plug question
Old May 3, 2008 | 09:42 AM
pastorattheridge's Avatar
pastorattheridge
freez plug question
88 f150 300 st6
Do I have to remove the head to remove the freez plug that is located on the back of the head against the fire wall. shoots out a stream of water about 1/16th of an inch.
can someone post me a picture of a head from a 300 so I can see this freez plug.
Old May 3, 2008 | 10:53 AM
F150xlt's Avatar
F150xlt
Here are two pics. of the freeze plug on the rear of the head. The engine is mounted on an engine stand.
It appears to be a 2 inch freeze plug.
Old May 3, 2008 | 04:22 PM
pastorattheridge
has anybody removed that freeze plug without pulling the head. I realy don't want to. It is only about 4" from the fire wall.
can I jsut cover the whole thing with jb weld.
Old May 3, 2008 | 05:31 PM
quicklook2's Avatar
quicklook2
do it right, replace it.
Old May 3, 2008 | 05:38 PM
netscaner's Avatar
netscaner
If you want to try JB Weld, I would use a stainless sheet metal screw with it.
You will also need a shorty screwdriver or angle screwdriver.
Find a screw about 1/2" long that snugly/firmly threads in about halfway. Then wearing rubber gloves, smear the JB alll around the back of the head and the threads. Then thread it the rest of the way in. Then coat over the whole thing with JB.
