Controller wiring questions
Old May 2, 2008 | 07:50 PM
Turbo_Bimmer's Avatar
Turbo_Bimmer
[1993 E250 5.8L and dual axle/single brakes car trailer]
Hello, I have some questions for the experts,
my friend gave me a Hayes 'time delay' brake controller. I installed it according to the instructions.
They specify that the black wire (+12V power) should be wired to the positive terminal of the battery via a resetable breaker. That's what I did but with that setup, the controller is always powered, and if my trailer is connected, the controller always shows a 'P' on the display to show in which mode it is set. So, I have the display active for 3 full days when I go to events.
Is this the way most people wire their controllers or a relay activated by the ignition needs to be inserted on the 12V wire?
My other question is about the 12V going to the trailer. I checked the trailer wiring just to make sure everything was ok and found that there is no 12V wire going from the plug to the battery.
The battery is not charged by the tow vehicle. That surprises me since it's a Parker trailer that came from factory with electric brakes and a battery. The positive wire from the battery only goes to the breakaway switch, then to the brake wire.
I do have a 12V wire on the truck's plug.
Do I only need to pass a wire from the trailer plug to the battery + wire? Or isolating diodes are required??
Thanks.
Old May 3, 2008 | 09:11 PM
F350-6's Avatar
F350-6
Most controllers are wired for a key on operation. It probably won't drain your battery down, but it's worth looking in to.
If you're referring to the battery for the break away, no it is not typically charged from the wiring. They're made to be replaced when the battery goes dead. Since there's not a constant draw on the battery there is no reason to continuously charge it
Old May 3, 2008 | 09:29 PM
rbaker6336's Avatar
rbaker6336
the breakaway batteries on all my trailers are charged from the truck
Old May 3, 2008 | 09:35 PM
F350-6's Avatar
F350-6
I guess I need to double check mine then. I don't think any of mine are.
