C8BA cyl heads..........
Old May 2, 2008 | 11:57 AM
jorgholio's Avatar
jorgholio
Hi again, tore down my engine today and found a few interesting things. I have a M100, body, frame all match up. Now pulled the heads and intake off and found some numbers. FR3019 on the block under intake also thier was a Z punched kinda over the last number. I also found that this has a 4 inch stroke. The cyl heads are 8BA and on the block on the back, it read C8BA. I've been looking all over the internet trying to figure all this out and I'm totally lost.
I thought a 4 inch stroke meant it was a 255. HELP!
Man I have alot to learn, thanks..........................................:c onfused:
Old May 2, 2008 | 12:13 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I forgotten most of it, hopefully someone will chime in soon, but here's what I think is correct.
8BA are 1949/53 239 heads.
The C of C8BA on the block denotes a Canadian 239 engine.
FR3019 should be FR6019.
Old May 2, 2008 | 12:23 PM
jorgholio's Avatar
jorgholio
'Thanks.............
Thanks, the part thats confusing, didn't the 239 have a 3.75 stroke where this has a 4 inch stroke? Can heads be interchanged? I'm lost
Old May 2, 2008 | 01:16 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Count yourself lucky! You have a "high compression" stroked Ford engine! By putting a Merc 4" crank in a 239 Ford, it makes your engine a 255, and raises the compression when retaining the Ford heads. Merc pistons are used with this combo.
Old May 3, 2008 | 07:48 AM
jorgholio's Avatar
jorgholio
Great!
This is great new$
Big-Sarge
6.7L Power Stroke Diesel
47
Jan 17, 2024 10:32 PM
bismic
Aug 10, 2015 10:35 AM
gray91
New Hampshire Chapter
87
Jun 11, 2008 10:53 AM
Monty06
Bronco II
Feb 15, 2005 11:07 PM
