Exhaust Tip Question
Old May 2, 2008 | 10:43 AM
matttaubert's Avatar
matttaubert
This may be obvious to others but I have to ask. I installed MBRP 4" with tip and after you install the tip are you supposed to cut back the exhaust to where the tip clamps on do you just leave the excess pipe remaining inside the tip?
Thanks for any replies.
Old May 2, 2008 | 10:47 AM
ron's power stroke's Avatar
ron's power stroke
i have the 5" with a 6" tip..at first i didnt cut it..after lookng at it for a couple months i had to..look bad from a far..the tone changed just a little after i did this to...
Old May 2, 2008 | 10:48 AM
powerstroke02's Avatar
powerstroke02
it doesnt matter. if the tip is 5 inch then you would get a little deeper tone when you cut the pipe but wont make much of a difference.
Old May 2, 2008 | 12:32 PM
TurtleRacing's Avatar
TurtleRacing
PSD Addict
I didn't cut mine just in case. Might decide I don't like the tip down the road, something might happen to it, whatever, not sure, I just left it for now. I might cut it later.
Old May 2, 2008 | 02:56 PM
farmb0y's Avatar
farmb0y
I fit mine up to make sure it looked how I wanted to, then cut it. I think it looks kinda cheap when you can see the exhaust pipe inside the tip, likes like a cheap add-on. I see it all the time on cars and other vehicles, just doesn't look as nice as when it's just the tip.
I wouldn't think that just the tip would be enough to change the tone, but mine is so noisy I wouldn't be able to notice anyway.
Old May 2, 2008 | 03:38 PM
jeff7825's Avatar
jeff7825
I didn't cut mine. I pulled the tip out far enough to where the normal person wouldn't see the pipe inside. Also it's so black inside there, you have to look hard to notice it anyway.
Old May 2, 2008 | 03:45 PM
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Ha, thanks, now I gotta go out and look and see what I did.
Old May 2, 2008 | 04:04 PM
Markadeck's Avatar
Markadeck
All I see is the MRBP stainless 5" tip. I gotta get on my hands and knees to even see the tailpipe. I left it sticking out just enough to avoid getting any soot on the paint. Did I cut it? I dunno. But I do know that coming loose has never been an issue.
