MAF conversion
Old May 1, 2001 | 04:02 PM
john91f150's Avatar
john91f150
MAF conversion
Hi, this is my first post to this forum. I am going to have to do a rebuild on my engine soon (91 351W). Before I do so, I want to gather as much information as possible on possible upgrades, etc.
I have read that I can convert my system to MAF, Is this possible on this engine? If so, I should then be able to change other components (cam, intake, exhaust, etc), correct?
If this is correct, I would like to convert to MAF and get some run time on the vehicle before I make the other changes.
Any help appreciated.
Thanks,
John.
91 F-150 5.8L 4X4
Old May 1, 2001 | 11:25 PM
mike460's Avatar
mike460
MAF conversion
well, as for the maf conversion, ford racing offers a kit for 87-94 f150s with 351 windsor(not lightning, and aod auto only) under part num m-9000-t51. as for mods, this should allow you to get the full potential out of a cam, intake, whatever swap you want. hope this helps. but i would suggest you pick up a ford racing catalog and possibly call their tech line to see if anything else is involved. good luck.
mike
Old Jul 5, 2001 | 10:38 PM
jruppert's Avatar
jruppert
MAF conversion
I think you can change pretty much everything except the cam on speed density. With the MAF you can change the cam plus it is more efficient with Hp and Mpg. I looked into this setup for my '88 F-250 and I found that Auburn Performance sells the same thing that Ford does but a lot less. I think through them it was around $500.00 that is the sensor, wiring harness, different tube (or air box), and processor.
Old Jul 6, 2001 | 08:10 PM
RonBo's Avatar
RonBo
MAF conversion
I did the MAF conversion to my Bronco, among other things.
MAF is better than speed density. It is a pre-event calibration, while the speed density is a post throttle event calibration. Without relying on the MAP sensor, you can put anything that reduces manifold vacuum you want (i.e. a BIG cam).
Motorsport kit is complete. Good instructions, easy to follow. Fairly easy swap ~4 hrs.
Biggest drawback is that the EEC module needs to be recalibrated if you go with larger MAF sensor, and injectors.
Old Jul 7, 2001 | 10:20 PM
lvstang's Avatar
lvstang
MAF conversion
nighthawk285
24
Jan 9, 2017 01:07 PM
BWD444
Dec 27, 2016 04:05 PM
Bruners4
1978 - 1996 Big Bronco
Mar 18, 2016 06:31 PM
gman97005
Jun 23, 2013 08:01 PM
SWAT KHAN
1997 - 2003 F150
May 13, 2012 09:52 PM
