pressing out lower balljoint
Old May 1, 2008 | 02:25 PM
86F150302's Avatar
86F150302
Well I put new balljoints into my new dream beams and when I go to put the nut on the bottom one it wont screw on. I look at it closely and see the thread is messed up. I messed with it for about 2 hours trying to fix the threads and just ended up going to autozone and getting another one. Now my question is can I press the lower ball joint out without having to take the upper out also? I have a rented ball joint press from autozone and I cant get it on right.
<a href="http://imageshack.us"><img src="http://img512.imageshack.us/img512/7045/truckroxy271fc1.jpg" border="0" alt="Image Hosted by ImageShack.us"/></a>
Old May 1, 2008 | 04:35 PM
Oscar Meier's Avatar
Oscar Meier
The botton joint comes out after the top - the tool fits up through the hole for the top joint to press out the bottom joint. Unfortunatly, pressing out the upper joint will ruin it.
Old May 1, 2008 | 05:26 PM
mhg's Avatar
mhg
if there is enough room for it to come out just hit it
with a BFH and a large drift or punch
its already damaged so no problem there
Old May 1, 2008 | 05:29 PM
86F150302's Avatar
86F150302
OK I took out the upper and then the lower out and now cant get the upper back in
Im just going to take it to a shop tomorrow to have them pressed in. Im tired of messing with them.
I got the passenger side ball joints in the dream beams fine. Just this side is being a PITA.
Old May 1, 2008 | 08:31 PM
uncle.stosh's Avatar
uncle.stosh
You could have just used a thread file on the lower ball joint and it would have been fine........
Old May 1, 2008 | 08:43 PM
ralf's Avatar
ralf
For future use, you can chase most threads with a die. The fine threads on a ball joint may not be in a standard SAE set of taps and dies though. I may have even learned this on this thread but you damage most threads when you cross thread a nut. To fix, just grind a taper on the end of the bolt.
Old May 1, 2008 | 08:48 PM
uncle.stosh
Or, just use a thread file like I said.
They are great when you don't have the correct die, and much cheaper than buying all of the dies that you could possibly use.
Old May 1, 2008 | 09:18 PM
86F150302's Avatar
86F150302
I didn't have a thread file and when I went to Autozone they didn't say anything about one. Autozone didn't have a die set big enough for the ball joint.
I ended up getting the ball joints on and got the driver side all done.
Hopefully Ill have no problems with assembling the passenger side. I have everything ready to go.
Old May 1, 2008 | 09:29 PM
uncle.stosh
These can save you a lot of headaches.
Old May 1, 2008 | 10:14 PM
ralf's Avatar
ralf
Thanks for the photo, I will pick one up. I suppose they come in metric and SAE. Too many tools not enough time . I used my buddy's tube bender tonight (the kind on the pedistal with a long handle) There is nothing like the right tool for the job. May not ever need one again but it was great to have to do the job right insted of rube-ing one together. I was bending 5/16 solid rod to hang the 4 inch straight pipe on my 7.3 oil burner. Thanks to this forum I installed new HP fuel pump last weekend.
Old May 2, 2008 | 08:13 AM
Oscar Meier
Good job, I like the red; but, it looks like you left the boot off the shock.
Old May 2, 2008 | 01:03 PM
86F150302's Avatar
86F150302
They dont come with shock boots.
Old May 3, 2008 | 12:53 AM
Sycostang67's Avatar
Sycostang67
Thats coming along nicely, you should paint your calipers while you have the wheels off. I used a dupi-color caliper kit I got at an auto parts store. It was $15 and came with everything I needed. It looks good, I did 3 coats on 4 calipers and still have 3/4 of a can of paint left.
Old May 3, 2008 | 12:45 PM
86F150302's Avatar
86F150302
I was thinking about it but then thought that with my wheels I have I don't think you would even see them.
Old May 4, 2008 | 02:37 AM
Sycostang67
Thats true, if you cant see them then theres no point in painting them. It's a good excuse to buy new wheels though.
