ISSPRO Transmission Temperature Sender needs
Old May 1, 2008 | 01:31 PM
SEK Archer's Avatar
SEK Archer
I have recently picked up a used set of ISSPRO gauges. Pyro, Trans Temp, and Boost gaugues along with all wires. The seller left the Trans Temp sender on the truck when he sold it and I need a replacement. They are the EV models and I believe the model for the Trans Temp is R6859 100-280 degF range.
Does anybody know where I can order only the sender?
Does anybody know what the resistance on a 0-1600 degF pyrometer should be?
Thanks!
Old May 1, 2008 | 01:35 PM
ggirten's Avatar
ggirten
You might try ISSPRO @ ISSPRO.com.
Old May 1, 2008 | 01:37 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I would think you could get one from here.
