Emblem Help
Old May 1, 2008 | 08:12 AM
Blacknav's Avatar
Blacknav
Emblem Help
Hi Guys,
I recently purchased a grill for my 98 Navigator. Issue is I need to reuse my emblem from the stock grill but can't get it out. I tried prying from the corners and even bending the grill to give me more space to work with. I called the local dealer and was told that the emblem is not sold separatley, only option is to buy a whole grill from them, but that leaves me in the same position
Has anyone ever removed the emblem successfully; If so can you please help me out.
Below is a link to the grill I bought.
98 99 00 01 02 LINCOLN NAVIGATOR CHROME BILLET GRILL - (eBay.ca item 310045871361 end time 03-May-08 18:24:43 EDT)
Old May 2, 2008 | 10:24 AM
Frat-man-du's Avatar
Frat-man-du
I suspect there is one bolt and double sided tape holdin it in place. You need to be very careful when removing. I have had luck with 3M's release agent. It softens the glue. Spray from the back side into the bolt hole, if possible.
you might want to check with Lincoln Motorsports (http://www.lincolnmotorsport.com/)for emblem options. They might be able to make one using the Cobrastar (Cobra and Lincoln emblem intertwined). I have their fender emblems on my 98 Mark and love em.
Old May 2, 2008 | 10:32 AM
Blacknav's Avatar
Blacknav
Thanks for the input Frat Man. I took the grill off and there is no bolt holding the emblem in. It is possibly double sidded tape but I havent been able to get anything in to pry the emblem (without chipping the side). I might just drill a small hole into the back of the grill (behind the emblem)and try the release agent. Is it called "3M Release agent"? would goo gone or goof off work the same way?
Old May 2, 2008 | 11:37 AM
Frat-man-du
Goof off might be too strong.
It might be Trim or Weatherstrip Release Agent. I got it at a body shop supply house for under $20. Just tell the clerk you need to remove a double sided tape emblem and they will know what you need. You might be able to use a hair dryer and heat it, but run the risk of damage to the plastic.
Also once you drill out the back, you might be able to gently 'push' the emblem out from the back.
Old May 2, 2008 | 03:59 PM
alloro's Avatar
alloro
Here' one up for bid for an 03-06 Navigator. Scroll down the page and look at the picture of the backside. It looks like there's some kind of hooks or tabs the insert into the grille.
eBay Motors: 2003-2006 Lincoln Navigator Grille Emblem OEM!!NEW!! (item 250242914653 end time May-06-08 17:56:56 PDT)
Old May 3, 2008 | 08:11 AM
Blacknav's Avatar
Blacknav
Thanks, Does anyone know if the emblem from 03-06 navigator is the same size? if so i might keep/sell the stock one as if and just buy this one
Old May 3, 2008 | 09:00 AM
alloro's Avatar
alloro
Don't know, but in that auction the guy says it's part number 2L7Z8213AA. Maybe with that number in hand you can get some information out of the dealer.
Old May 7, 2008 | 12:35 PM
Frat-man-du
I ran the part and it shows 2L7Z8213AA, EMBLEM FRONT GRILLE, 02-06 so it would seem to be the same, check with a dealer to be sure.
Old May 7, 2008 | 12:54 PM
Blacknav's Avatar
Blacknav
Thanks guys, So I drilled a small hole and couldn't see any type of tape or glue so I made a larger window using my Dremel, then just pushed it out. FYI...The emblem is held on by two globs of silicone, (one on top and one on bottom ) which is why I couldn't see anythign with the hole I drilled in the middle. I'm sure soaking it with something that will soften the silicone woudl allow you to push it out as well. I'm not sure what checmical you would need to use to do this to Silicone but I'm sure something is out there. Hopefully this helps someone else in the future.
Supercab
Aug 22, 2009 06:03 PM
Supercab
13
Apr 30, 2009 11:32 AM
fordtrucklover94
Appearance & Dress-Up
Jul 10, 2008 04:13 PM
jcb67
Dec 24, 2003 02:26 AM
