AC wont cool
AC wont cool
OKay i dont know if its my browser (firefox) but the search feature right now is not working. My 92 2.3 ranger wasnt cooling and i found a leak in the high pressure hose. I replaced it vacuumed out system and recharged with 134. It cooled for about a week and a half. THis morning i heard it kicking on and off on and off, almost like it doesnt have enough freon. I will check the pressure tonight but was curious where some other leaks might be hiding?
After i replaced high pressure hose it held a vacuum for like 20 mins and i assumed there were no leaks.
Just looking for ideas as I noticed it wasnt cooling on the way in to work.
77F 70%humidity here.
You will also need to replace the accumulator. It contains a drier that protects the AC system. Once the system has been opened up, the drier is likely contaminated with moisture. The humidity in your area is a bit high, which would mean that as long as your system was low on coolant, it was exposed to moisture. Once the desiccant inside the accumulator becomes saturated, it can no longer protect the cooling system and the compressor will be damaged. While you are at it, get a new orifice tube. You can borrow the special tool to remove it from your local parts store.
OKay i have ordered a condenser and its on the way. I also purchased a dryer and orfice tube.
I bought some flush / cleaning stuff at auto zone and was curious how to flush compressor and evaporator. Does it matter which hose you flush from? The compressor has 2 hoses coming from it a high side and low side im guessing. Which port should i pump the cleaner / air into or can it go either way? Also for the evaporator there is a hose at top and bottom which way should i flush that? Any help would be appreciated.
Thanks,
Chaz
Thanks,
Chaz
Thanks,
Chaz
Thanks,
Chaz
To flush the system, you need LOTS of compressed air. You flush each component individually and blow it completely dry inside. Any residual flush solvent WILL damage the compressor. You may have to get creative to flush the evaporator. Replace all of the o-rings on the hose connections and the 2 seals at the compressor manifold. (don't forget the one on the cycling switch fitting).Don't flush through the accumulator, old or new.
You don't flush the compressor with solvent. You add the type of oil that you will be using, turn the compressor a few times, drain, repeat, repeat, and repeat. Drain as much oil as possible out the last time by holding the ports downward and turning the shaft.
As you reassemble the system, spread the recommended amount of oil between the condenser, evaporator and accumulator.
Being a 92, you will be converting to R134a. Stay away from the cheap aluminum Interdynamics conversion fittings, they are terrible for not sealing. Spring for brass fittings from NAPA.
If you've already ordered the o-tube the original type will be ok, but if you still have a choice get a blue one. They work a bit better with R134a.
Once charged to the proper weight, turn the screw between the terminals of the cycling switch counterclockwise 1.25-1.5 turns to drop the evaporator pressure to 26-28psi.
If you find that the cooling wheezes out at idle or low speeds, replace the fan clutch with a new Motorcraft unit. Don't bother with an aftermarket clutch, they just don't move enough air to do the AC much good.
Hope this helps.
Hope this helps.
