1985 ford info needed
Old Apr 30, 2008 | 06:07 PM
CDF302v8's Avatar
CDF302v8
<HR style="COLOR: #d1d1e1" SIZE=1> <!-- / icon and title --><!-- message --><TABLE width="100%" border=0><TBODY><TR><TD vAlign=top>Does anyone know how much torque and hp a 1985 ford f150 with a 302 V8 has?
Thank you!
</TD></TR></TBODY></TABLE>
Old Apr 30, 2008 | 07:16 PM
uncle.stosh's Avatar
uncle.stosh
Not enough.........
Old Apr 30, 2008 | 08:09 PM
85e150's Avatar
85e150
SOMEWHERE on here there was a chart of all the engines over the years. I can't find it.
APPROX IIRC numbers:
HP: 185 @ 4400 rpm
Torque: 255 @ 2400-2800 rpm
+/- a bit, maybe, possibly.
This will bring the chart out of course...
Old Apr 30, 2008 | 08:11 PM
bedmondo's Avatar
bedmondo
i dont know of the rpm levels but i thought it was 185hp and 275lbs torque
Old Apr 30, 2008 | 11:55 PM
Piffery1's Avatar
Piffery1
1983 49 States: 119 hp @ 3400 rpm, 250 ft-lb @ 2000 rpm.
1983 Calif: 141 hp @ 3600 rpm, 249 ft-lb @ 2000 rpm.
Per 1983 Ford Light Truck Specifications Book.
Old May 1, 2008 | 09:47 AM
Sycostang67's Avatar
Sycostang67
Originally Posted by uncle.stosh
Not enough.........
Haaahaaahhaaaa
Old May 1, 2008 | 02:39 PM
85e150's Avatar
85e150
Every year in the '80s the HP went up, esp. when the engines when EFI.
In the above specs, is it possible the 119 hp for 49 states is typo, and should be 149?
Old May 1, 2008 | 11:10 PM
klause85f150's Avatar
klause85f150
Originally Posted by Sycostang67
Haaahaaahhaaaa
Hell, I have an 85 351 and it's bad, I can't imagine how bad it is for our smaller bretheren.
Cheers!!!
Old May 2, 2008 | 03:30 AM
srercrcr's Avatar
srercrcr
119 hp is correct. about the same as the six cylinder. After all, it's 302 ci vs 300 ci.
Old May 2, 2008 | 04:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
119 = Certified Net Horsepower.
Old May 2, 2008 | 05:28 AM
ri_truck_guy's Avatar
ri_truck_guy
It's the torque figures that surprise me...I've alsways been told the 302's power band is much higher the a 300's. Peak torque at 2000 rpm is something I would expect from the 300 with a 302's being somewhere around 3000 rpm.
Horsepower is nothing more than an artificial number to describe how fast an engine can generate torque. It's not really the important number.
Old May 2, 2008 | 02:14 PM
85e150's Avatar
85e150
The reason I question it is the California number is 141 hp in that post and 49 state numbers are usually a bit higher, not 22 horse lower.
Yea, hp is an artificial number but it serves as a reference point and if calculated according to a set standard, allows a meaningful comparison between engines. Thus, even though the torque figures are similar between the 300 and 302, the HP figure tells the rest of the tale on power. You could do the same thing with another torque reading at peak rpm, but the HP figure is easier to deal with.
