Front axle carnage....
Old Apr 30, 2008 | 04:24 PM
TheTinian's Avatar
TheTinian
Took the truck out last weekend and tried to pull a buddy out of the mud and managed to snap my drivers side front axle. I just got the stock Dana 44 frotn end in it. Iv heard this is the "HD" front end. Will any 44 axle fit...such as out of a mid 80's truck, or am i going to have to find one for this specific truck. And what is the difference between a "HD' and a regular 44??
Old Apr 30, 2008 | 05:29 PM
flcracker9's Avatar
flcracker9
The HD 44 axle has larger axle bearings and larger locking hubs, but the axle shafts are the same as the regular duty. No, the shafts from an eighties model won't work, they have the TTB axles in them.
Old Apr 30, 2008 | 06:06 PM
MBBFord's Avatar
MBBFord
The D44HD was in all standard F250 4x4s.
It's basically a D44 with 8 lug outers and it has leaf springs instead of coils.
Like flcracker9 said, 80s axle shaft won't work.
Did it take out the u joint and ears on the shaft, or just snaped the shaft?
IF it were me, I'd upgrade to chromoly shafts and some good quality spicer joints on both sides, but you could get just one for the side you broke for a little more than the price of a stock shaft.
Old Apr 30, 2008 | 06:55 PM
73 ford guy's Avatar
73 ford guy
Its not true carnage until you do this!!! Dana 44's suck.They do work good to hold down a tarp from blowing away when you actually have something valuable to cover...
Old Apr 30, 2008 | 06:59 PM
Eagle460's Avatar
Eagle460
No wonder, look at the size of those tires. The Dana 44 will handle a good amount of abuse, but it's no hardcore offroad diff
Old Apr 30, 2008 | 07:20 PM
73 ford guy
Thats what happens when you take it off some "sweet" jumps : )
Old Apr 30, 2008 | 09:25 PM
boggin79ford's Avatar
boggin79ford
chevy dana 44 axle shafts will also work
Old Apr 30, 2008 | 09:41 PM
MBBFord's Avatar
MBBFord
WHAT???????????????????????????????????????????
Old Apr 30, 2008 | 10:18 PM
73 ford guy
haha I know I seen that too but never said anything
Old Apr 30, 2008 | 11:43 PM
RCrawler's Avatar
RCrawler
All depends on tire size and weight. I've abused the snot out of my 44, running up to 38" swampers. After I upgraded to decent shafts and spendy u joints, I quit having to change them every trip.
Obviously, a 44 under a fullsize is not going to last if you pitch the front end on a jump. I don't think a 60 will fare much better. I've seen them break like that under similar "conditions" too. They just aren't made to fly without some work done.
Jason
Old May 1, 2008 | 05:09 PM
TheTinian's Avatar
TheTinian
I know that the TBB front ends are different, but they are still a solid axle in it, thats why I thought maybe they would work.
Old May 1, 2008 | 06:18 PM
MBBFord's Avatar
MBBFord
I don't like hearing a sentence with
TTB
are (&)
solid axle
in the same sentence....
Since you have a F250 using the leafs would make things easier, but TTBs aren't solid axles
Old May 1, 2008 | 10:19 PM
TheTinian's Avatar
TheTinian
I know they are not solid axles...obviously. What I am talking about is the axle shafts are a solid strait axle, are they not?? And what do you mean using the leafs???
Old May 1, 2008 | 10:33 PM
MBBFord's Avatar
MBBFord
If you call 3 u joints seperating them solid, then yes.
Ignore the leaf spring comment, I was thinking of another thread.
Old May 1, 2008 | 10:44 PM
crescentwrencher's Avatar
crescentwrencher
brain fart!!!
