Time to replace the starter?
Old Apr 30, 2008 | 12:56 PM
Fal Grunt's Avatar
Fal Grunt
Truck won't start until I whack the starter with a Hammer.
Time to replace it?
-myers
Old Apr 30, 2008 | 01:07 PM
underh2o2long's Avatar
underh2o2long
Time to replace it?
-myers
Nine times out of ten its the small wire going to the starter... replace the first 6-8" of wire going to the starter. Mine did the same thing.
Old Apr 30, 2008 | 01:09 PM
Animalistic's Avatar
Animalistic
My guess would be yes unless you like wacking things with a hammer.
Old Apr 30, 2008 | 01:25 PM
quicklook2's Avatar
quicklook2
sounds like it is working just fine.
Old Apr 30, 2008 | 03:51 PM
12secondstang's Avatar
12secondstang
Check the little wire and the solenoid before changing the starter. I did the same thing with mine, changed the starter first only to find out it was the solenoid later.
Old Apr 30, 2008 | 08:11 PM
Secret Agent 069's Avatar
Secret Agent 069
Pull the starter, clean it up (Ford Starters die real fast when get covered in oil & crap).
Check the braided copper wire from the solenoid to the starter, and then pull the starter apart and make sure you haven't cracked the magnet, and check the brushes. Replace the Brushes and the braided copper wire, put the whole thing back together.
Poof you have a brand new (rebuilt) starter for less that $50.
Christie1984
24
Jan 9, 2023 07:48 AM
Automator
17
Aug 15, 2013 02:42 PM
dalkris95
Sep 17, 2012 02:57 AM
bob the viking
Jan 31, 2010 10:06 PM
wheel2
1983 - 2012 Ranger & B-Series
Jul 27, 1999 03:40 PM
