Power Steering Gear Box
Old Apr 30, 2008 | 11:37 AM
Pookie's Dad's Avatar
Pookie's Dad
Going to order a new gear box. When I called NAPA to order one, I was ask if I needed the 36 or 32 Spline Output Shaft. Is the 36 is for the 4-wheel drive and 32 is for the 2-wheel drive?
Old Apr 30, 2008 | 12:11 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Usually the counter boy should ask what you have if there are two different parts for the same truck. I woul ask them the difference if it was me.
Old Apr 30, 2008 | 08:22 PM
rustydailey's Avatar
rustydailey
You just need to go and count the splines on the current one. Mine was a 36.
Old Apr 30, 2008 | 08:32 PM
leekingen's Avatar
leekingen
that's the spline's on the pitman arm. you will nead to remove the pitman arm to count
the splines no other way to know. best way to do this is remove the gear box and take it with you to napa.
Old Apr 30, 2008 | 08:35 PM
rustydailey
You should be able to count them without removing the pitman arm.
