Nut check
Old Apr 30, 2008 | 11:33 AM
smoky_diesel's Avatar
smoky_diesel
Nut check
If you have a lift that included a drop pitman arm.....
Check your nut on the end of your (sector) shaft next time you're looking at your undercarriage.
I found mine finger tight looking for the cause of a clunk when turning the wheel past center. I installed the lift myself a few years ago and torqued the nut to 200ft/lbs as stated in the destructions. I was paranoid so I marked the nut and arm with a paint marker and checked it over a few thousand miles and it didn't move. well, since then it did.
Glad I didn't get myself and/or my family killed.
Old Apr 30, 2008 | 11:53 AM
bigjake0524's Avatar
bigjake0524
I also have a clunk when turning, guess I will start by checking that but I only have a leveling kit and nop pitman arm changes but will check it anyways, nice catch glad you didn't end up in a wreck.
