looking for some advice
Old Apr 29, 2008 | 06:53 PM
elkarcher's Avatar
elkarcher
I own an '04 f-250 with 48k miles on it. At 38k miles i had head gaskets, EGR cooler, all glow plugs on right side and a fuel pressure regulator replaced because I was smelling coolant inside the cab. 10k miles later I am smelling coolant in the cab again. My problem is #1. Do I want to keep this truck beyond the warranty or get rid of it in fear that I will have these problems again after it is up and have to pay out of pocket. Or #2, do I get the gaskets done again, this time with new studds and hope for the best knowing I just added a new entry on my oasis report(looking bad to a possible future buyer). I really love the truck and besides the problems listed above have had no other concerns. Does Anyone have a crystal ball?
Thanks, Elkarcher
Old Apr 29, 2008 | 07:00 PM
KRDiesel's Avatar
KRDiesel
I have 140K on mine, Have the dealer look at it, there is no reason that a cooler should go out again. Also if you run with the EGR unpluged it will help keep the cooler from going bad.
Old Apr 29, 2008 | 07:26 PM
msgtg's Avatar
msgtg
Are you the original owner? Did your dealer do the work?
Joe
Old Apr 29, 2008 | 07:36 PM
BGMSPD's Avatar
BGMSPD
I would see another dealer if you have that option. Gaskets going again only sounds to me like they weren't done right the first time. I have only 22k on my 04 but i've beat the **** out of it since i got it with 13k and have no major problems yet.
Old Apr 29, 2008 | 07:43 PM
elkarcher's Avatar
elkarcher
I am not the original owner but the gaskets were done by my dealer. Those were my thoughts also, if I have them done again I would get them done somewhere else.
Old Apr 29, 2008 | 10:49 PM
thedaddycat's Avatar
thedaddycat
Since this is the second time, I'd have them check the heads to be sure they are within spec for flatness. I think I read on this site that anything over .002 out was cause for replacement but I'm not 100% on that...
Old Apr 29, 2008 | 11:01 PM
doubledee715's Avatar
doubledee715
the warranty will go out the window after the dealer installs the studs, if you're lucky enough to find one. Do you tow? If so, how often?
Old Apr 29, 2008 | 11:18 PM
brickie's Avatar
brickie
Grab a flash light and look at the valley on the motor.I bet its wet. Head gaskets without coolant loss or overheating isn't the norm.If you aren't puking or missing coolant I would look else where first.
Old Apr 30, 2008 | 08:12 PM
toolman05kr's Avatar
toolman05kr
Just a thought, have you checked the heater core? It's not uncommon for the heater core to fail after head gasket issues. And it will give a coolant smell inside the cab.
Old May 4, 2008 | 02:20 PM
elkarcher's Avatar
elkarcher
Thanks for the replys guys. The truck goes to a different dealer for tests tommorow. I was assuming that when they did the gaskets last time they would check the heads for flatness but you never know anymore. You know what they say about assuming. You have all given me some things to think about and I appreciate it! Is it expensive to have the studds put in while they are in ther doing the gaskets under warranty. I think since I am so close to my warranty being up, it might be a good idea.
Thanks, elkarcher
Old May 4, 2008 | 09:07 PM
doubledee715
hand the tech the studs and maybe one or two hundred bucks in cash and Im sure he'd put them in.
