Sponsored by: Auxito
Outside mirrors
Old Apr 29, 2008 | 11:59 AM
semi 104's Avatar
semi 104
Outside mirrors
HI: New here:
Having trouble with my outside mirrors.
A 2000 Ford 1/2 ton 2 wheel drive with power mirrors.
Both work up & down but not side to side.
My son & I tried to take the glass part out but could not figure out how to do it with out breaking the glass .
We checked out the switch & it seams OK.
Help Please.
Thanks
Old Apr 29, 2008 | 01:39 PM
ground_zero298's Avatar
ground_zero298
Probably just need a new switch. Mine use to do it when ever it got wet. I cleaned it out the first 2 times then replaced it the third time it did it. No problems after that.
Old Apr 29, 2008 | 02:21 PM
semi 104's Avatar
semi 104
HI & Thanks
Thanks & where did you get the switch??
semi 104
Old Apr 29, 2008 | 02:56 PM
ground_zero298
i got mine from a salvage yard.
Old Apr 29, 2008 | 04:23 PM
ncranchero's Avatar
ncranchero
Spray it with electrical contact cleaner and lube it with WD40 or similar. Work the switch repeatedly in all directions and blow it out real good. I got one at the salvage yard that worked in 3 of the 4 directions. Did the above and it works like new now.
Old May 5, 2008 | 10:35 AM
semi 104's Avatar
semi 104
HI:
Thanks to all who answered my Question.
I took it off & did spray it
& worked the switch back & forth & now it works great.
Again Thanks
