Sponsored by: Real Truck
Pyro gauge readings
Old Apr 29, 2008 | 08:06 AM
G-Man16's Avatar
G-Man16
Pyro gauge readings
I recently installed pillar mount gauges in my 2004 6.0 psd and was wondering what the proper shut down temp for pre turbo is. Thanks
Old Apr 29, 2008 | 08:28 AM
tex25025's Avatar
tex25025
I usually shut down ~350-400. I have a turbo time on my alarm system, but I have gotten to the point that I don't like running the truck the extra two minutes with my not being in there.
Old Apr 30, 2008 | 06:38 AM
glsurratt's Avatar
glsurratt
It depends on your starting point for the temperatures. Most will recommend between 350 and 400 degrees for shutdown. I shutdown at about 450. My starting temperature after the truck has been sitting overnight in 40-50 degree temperatures is 90-95 degrees whereas my coolant and tranny temps read 40-50. I figure my pyro reading is about 50 degrees high all the way around.
Old May 1, 2008 | 09:28 AM
G-Man16's Avatar
G-Man16
Thanks guys. That seems to be the temps everybody goes by.
Old May 1, 2008 | 09:30 AM
G-Man16's Avatar
G-Man16
Thanks for the resonse glsurratt.
Old May 1, 2008 | 09:31 AM
G-Man16's Avatar
G-Man16
Thanks for the response tex25025.
