Help Diesel Fuel Problems?
Old Apr 29, 2008 | 07:37 AM
Bill_a's Avatar
Bill_a
Exclamation Help Diesel Fuel Problems?
97 F-350 Powerstroke
The engine will sometimes just shut off as if I turned the key. Intermittent. it will start back up. Lately getting worse. Driving down the road it can shut off and come back on. There are three keys pieces to the fuel supply, fuel pump, injector pump and the injector Driver Module. I am thinkng the electronic component but I don't know whether low pressure could cause something intermittent. 157K on the truck.
No OBD codes register
Has anyone had this problem?
Please help
Thanks
Old Apr 29, 2008 | 08:52 AM
superduty4x4's Avatar
superduty4x4
Sounds like a bad CPS to me, have you had yours replaced under the recall yet? If not take your truck to a Ford dealer, they'll put in a new CPS for you and send you on your merry way. It's a good idea to carry a spare in the glovebox too in case on quits you on the road. In case you're not up on the acronyms, CPS stands for cam position sensor.
Old Apr 29, 2008 | 09:26 AM
plowhand's Avatar
plowhand
Playing in the Dirt
Agreed, sounds like it's time to change your CPS.
Short version of our fuel system: our trucks have a 2 stage fuel pump that lifts fuel from the tanks and pumps it through the filter system under low pressure and then to the high pressure side of the pump where it is pumped under high pressure through the fuel passages in the heads to the injectors. The IDM sends voltage to the injector solenoids to open the injectors to allow fuel to be sprayed into the cylinders.
For detail info on the injection systems, check here: PowerStroke
Old Apr 29, 2008 | 10:10 AM
Neal 97 250's Avatar
Neal 97 250
Agreed CPS. Mine recently did the same thing.
Old May 1, 2008 | 07:27 AM
Bill_a's Avatar
Bill_a
thanks
i went and entered my vin on the ford website and had the cps replaced yesterday
i hope it last another 150K
thanks
Old May 1, 2008 | 07:31 AM
Bill_a's Avatar
Bill_a
Great Wbsite:Thanks for all the replies
it was the CPS
i would have never thought about the CPS
still learning about diesels
would not trade for the world even with $150 fill ups
thanks
Old May 1, 2008 | 07:34 AM
MADVAN's Avatar
MADVAN
Sometimes its the simple things.
Bill
Old May 1, 2008 | 07:50 AM
Neal 97 250
Glad it worked out for ya. Stick around here and you will be an expert (self proclaimed) in no time.
