Head leaks Affect Idle?
Old Apr 28, 2008 | 11:14 PM
casey8981's Avatar
casey8981
Hello. New to the site.
I just bought a 97 4.0L Ranger. It wont stay running. it will start but then die unless you give it alittle gas.
Anyway....
The prior owner said he had a compression check down and the mech that done it said he had a blown head gasket or a warped head because of the low compresson readings.
Anyone know if .. there anyway this will cause the stall/idle problem i mentioned?
Thanks
Old Apr 29, 2008 | 12:27 AM
FORD RANGER's Avatar
FORD RANGER
hey man,
congrats on your first post!
you could have a cracked head to!
ford ranger
Old Apr 29, 2008 | 12:30 AM
rob188's Avatar
rob188
a cracked head would give you a lower compression which would mean that your engibe won't keep a high idle
Old Apr 29, 2008 | 03:19 AM
casey8981's Avatar
casey8981
Question Thanks.
I guess that makes sense. I already started tearing down the engine. 1st time I ever done it. Kinda fun.
I seen some orange stuff in the head below the intake manifold rear port.
anyone know what this mean or is. Here is pic of it.
Also. Its looks like I have to remove the studs coming out of the head into the exhause manifold. Is there a special tool for that. The Hayes manuel just say remove the bolts and pull it off. Nothing about studs being removed.
Thanks again.
Old Apr 29, 2008 | 03:56 AM
casey8981's Avatar
casey8981
Thanks. Hopefully changeing them will work//
Originally Posted by FORD RANGER
hey man,
ford ranger
Old May 1, 2008 | 10:28 PM
rob188's Avatar
rob188
well if your head has studs theres a special 9 point socket you can get to remove it
