351W Question
Questions:
Oil Pan: The engine came out of car, so it has a dual sump pan. Will that fit or will I need to find a rear sump pan??
Flywheel: Both are from an auto, will it bolt up??
Linkage: I'm sure I can figure it out, but any advice on how to mount the linkage for the carb??
I've already decided to just get a regulator instead of messing with the fuel lines.
Also I have a duraspark II ignition so that is figured out, and I am leaving the computer in for tranny even though it doesnt shift until ay lat anyways if at all.
Is there anything I am overlooking??
Any help with any of the above would be much appreciated as I am doing the swap tomorrow, thanks, robert
