Sponsored by: Real Truck
Pull after braking ?
Old Apr 28, 2008 | 08:10 PM
07FX4's Avatar
07FX4
My 05 F250SD will sometimes pull to the right after I let off the brakes. It doesn't pull while braking. I have searched here and found that it could be a few different things. Is it more likely a sticky caliper piston, or do my caliper slide pins need to be lubed? Which is more common?
Old Apr 28, 2008 | 08:46 PM
99whiteford's Avatar
99whiteford
A bad brake line will cause the same problem.(The rubber one going to caliper)I had a friend with the same problem on his truck.the pressure from the master cylinder will force the fluid thru but line collapses when pressure is removed and will not let fluid return.
