460 Vaccum Help!
Old Apr 28, 2008 | 03:38 PM
dkhollins's Avatar
dkhollins
460 Vaccum Help!
I'm reinstalling my motor and want to delete the EGR, TAB and TAD from the motor. I've deleted the EGR with a plate and added the EGR delete resistor from rjminjection.com. Now as for the vacuum lines what can I remove and block off?
More specifically on the coil plate there are 2 solenoids, what are these exactly? I was thinking the EVR and the TAB/TAD solenoid? Can I remove them both and add a resistor?
Also, the MAP sensor is on the firewall on the passenger side, right? Where does the vacuum line from that sensor connect?
Thanks for any help...
