Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
tranny swapping- E4OD to ?
Old Apr 28, 2008 | 02:34 PM
Brads77f150's Avatar
Brads77f150
Hi just wondering if anyone can tell me if there is any other transmission (automatic or manual) that can bolt right up in place of my E4OD behind my 5.0L in my '92 2wd F150? Preferably a direct bolt in without too much change (bell housing,mounts, drive shaft.....). Thanks
Old Apr 28, 2008 | 05:58 PM
preppypyro's Avatar
preppypyro
Well, you can do an AOD, or a 5 speed. With a 5 speed you have the clutch pedal and resovoir under the hood to install. With the aod it would work, but I think you MAY trip a code. You MAY have to change your computer over to a comp from a truck with an aod, or manual.
Im curious though, why do you want to swap out that e4od?
Old Apr 28, 2008 | 06:07 PM
Brads77f150
My transmission is really acting up. I have no "Park". When you put it to "P", it just goes into reverse yet there is a noticeable shift between "P" and "R" . So I end up leaving it in "Neutral" with the parking brake on.
My main "Drive" is also shot...it will move forward, but it is like its stuck up to the hubs in mud, you have to rev the heck out of it to move.
The lower forward gears are fine and reverse is perfect. I went to a nearby garage and they told me I need a new tranny. The cost of replacing it will be in the 2 grand range, so I am seeking alternative ideas.
Old Apr 28, 2008 | 09:36 PM
Snowking's Avatar
Snowking
if you do got decide a standard you should go with a hydralic clutch, NOT mechanical linkage. But save yourself the headache and stick with a auto.
But any 300, 302,351W tranny shall work but to avoid switching parts around from your old one try to find a tranny round the same age.
Old Apr 28, 2008 | 10:21 PM
preppypyro's Avatar
preppypyro
Are you totally against getting another e4od? Of course that would be the easiest option, and from everything i have researched they are supposed to be a pretty tough tranny.
As always a 5 speed would be cool, but Ryan is right, it could be a pretty big headache.
Theres a guy Paul (conanski) in the 87-96 forums that is really knowledgable with this stuff, you should pop in there and ask him what he thinks.
Nathan probably will pop in here with some more specifics too he knows this kinda stuff pretty good.
Old Apr 28, 2008 | 10:32 PM
96sherm's Avatar
96sherm
i'd either swallow the 2g's and rebuild, or drop in a used one... the e4od is a pretty good tranny really. i wouldn't bother trying to find an alternative, too much headache and possibly as much money in the long run as well...
Old Apr 28, 2008 | 10:36 PM
Dustin1690's Avatar
Dustin1690
Yes indeed conanski is pretty knowledgable yeah the E4OD is a good tranny just the odd ball one had its issues but i would get it rebuilt or replaced
Old Apr 28, 2008 | 10:43 PM
Brads77f150
Thanks for all the good info. I think I will just get a replacement E4OD. This is a great truck and the only issue it has is the tranny.
Old Apr 28, 2008 | 10:47 PM
Snowking's Avatar
Snowking
But heck spending 2G on a rebuild? Alot of 87-96 F150's you can get for that price.
Old Apr 28, 2008 | 10:53 PM
preppypyro's Avatar
preppypyro
Good call Ryan, I would have a tough time spending 2 grand just on a tranny myself.
Keep your eyes open and you can find a good used one. Throw a shift kit in it to stiffen it up abit and you will have a tough reliable tranny.
Old Apr 28, 2008 | 10:55 PM
Snowking's Avatar
Snowking
Heck I just sold my 93 for 1700, that had a good tranny.
Old Apr 28, 2008 | 10:59 PM
preppypyro's Avatar
preppypyro
I even wonder how much one would be from a wrecker? I wouldnt guess more then 500 bucks. Might get a gaurantee on that too.
Old Apr 28, 2008 | 11:03 PM
96sherm's Avatar
96sherm
thats a good idea too...
Old Apr 29, 2008 | 09:54 PM
Dustin1690's Avatar
Dustin1690
Wrecker would be your best bet then get it rebuilt if necessary
grayghost316
Aug 7, 2024 10:39 AM
therigwelder
Apr 3, 2014 08:29 AM
fudimanuchi
Apr 1, 2012 07:06 PM
moostadon
May 26, 2011 04:09 PM
padutch
May 20, 2002 09:26 PM
