Choke Pull off?
Old Oct 24, 2001 | 05:30 PM
aintskeered's Avatar
aintskeered
Choke Pull off?
[font size="1" color="#FF0000"]LAST EDITED ON 24-Oct-01 AT 06:57 PM (EST)[/font][p]How do you know when your choke pull off is bad? How does it actually work? Can anyone please help me?
Old Oct 24, 2001 | 09:19 PM
Franklin2's Avatar
Franklin2
Choke Pull off?
If the choke pull off doesn't work, after starting the vehicle, it will act as if it is flooding and will run rich. The pull off works on vacuum. When the choke is first set in the morning, it will go completely shut. This is ok to start the engine, but after the engine starts running, the choke pull off cracks the choke butterfly open a little so the engine won't run too rich. Some carbs had an external diaphram with a lever that pulled the choke open. Some have a piston that is built into the carb behind the round black choke housing. Most of these have an adjustment from the factory that you usually don't have to mess with. I mention this, because the pull off can be adjusted where it opens the choke butterfly too much, and will cause the engine to stall.
Old Oct 24, 2001 | 09:22 PM
Franklin2's Avatar
Franklin2
Choke Pull off?
reno138
Jan 20, 2016 04:57 AM
RANGER589
18
Jun 3, 2011 10:03 AM
68fordf250
Apr 29, 2011 01:08 AM
PacoLips
Oct 6, 2010 07:12 AM
JimsRebel
Nov 28, 2009 08:16 AM
