Modular V10 (6.8l)
Bucking under load
Old Apr 27, 2008 | 08:18 PM
MD V10's Avatar
MD V10
Bucking under load
2001 F250 4x4, 65,000 miles, Plugs changed 2,000 miles ago,new fuel filter. Truck bucks at 2000 2500 rpms when pulling a hill or pulling a load. Getting worse. Any ideas?
Old Apr 27, 2008 | 10:50 PM
biz4two's Avatar
biz4two
Arrow
Could be your MAF sensor. They are easy to remove and clean with electronics cleaner. Then re-install after it air drys.
Hope this helps...
biz
Old Apr 28, 2008 | 01:02 AM
Monsta's Avatar
Monsta
Sit. Stay.
Probably a COP, boot or plug. Who did your plugs?
Old Apr 28, 2008 | 07:04 AM
MD V10's Avatar
MD V10
I did the plugs. It started out very weak. But now you can realy feel it.
Old Apr 28, 2008 | 07:05 AM
MD V10's Avatar
MD V10
Hope this helps...
biz
Thanks I'll give it a try.
Old May 8, 2008 | 12:26 PM
MD V10's Avatar
MD V10
Cleaned MAF sensor with MAF sensor cleaner. Truck runs alot better but now I get an ocasional buck/shaking at around 12-1400 rpm's. Any ideas?
Old May 8, 2008 | 01:28 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Reset the PCM after the MAF clean - disconnect the battery and leave it for a few hours with the headlight switch on.
Did you get the plug back into the air filter housing where the MAF wires go through?
Also, check for vacuum leaks.
I was going to say check fuel pressure, but if it stopped the constant bucking under load by cleaning the MAF, that's not the issue
Old May 8, 2008 | 08:30 PM
MD V10's Avatar
MD V10
Don't have the housing with the plug. I put a K&N on 2 years ago.
Old May 8, 2008 | 10:17 PM
biz4two's Avatar
biz4two
Arrow
Also...after resetting the PCM...make sure to do the following "learn" strategy...
#1. 10 minutes of continuous highway driving
followed by
#2. 20 minutes of continuous city driving (stop and go)
Hope this helps...
biz
Old May 9, 2008 | 11:02 PM
super 6.8's Avatar
super 6.8
Any problem under load and the first thing I would change is the fuel filter.
Don't overlook it.
Old May 10, 2008 | 01:06 AM
dew the thunder's Avatar
dew the thunder
Get it fixed? Had the same kind of problem on my Thunderbird before she got wrecked and always wondered what it could've been...
Old May 10, 2008 | 07:14 AM
MD V10's Avatar
MD V10
Don't overlook it.
The first thing I did was change the fuel filter. It seemed to make it worse.
I'll try resetting the computer again today.
Old May 10, 2008 | 01:31 PM
Monsta's Avatar
Monsta
Sit. Stay.
I'm tellin' ya...you got a bad COP.
Old May 10, 2008 | 06:45 PM
Skoda's Avatar
Skoda
agrred, pull out a good old odb2 scanner and see if you have any codes, if you don't have a code reader drop by your local auto zone, I've heard they do it for free
Best of luck tracking down your problem
Skoda
Old May 10, 2008 | 11:34 PM
MD V10's Avatar
MD V10
Thats what I'm thinking now after reading posts on COPs. Any easy way of finding the bad one, I dont know anyone with a scanner. Could you tell by looking at the plugs? Or should I just buy a new COP and keep swiching it till I find the bad one.
Also I noticed today a sound like valves tapping. Oh I tried resetting the computer today, no luck.
