Now pass side power window not working.
Old Apr 27, 2008 | 07:52 PM
kenthorn's Avatar
kenthorn
If its not one thing its another. When I picked up truck from shop noticed pass window switch acting like it had short luckly I was able to get window up,but now it doesnt work at all. What trouble shooting do I test first and is it very hard to put window motor in?
Old Apr 27, 2008 | 08:21 PM
mfp4073's Avatar
mfp4073
will it go up or down with the switch from either side? Or are both sides dead?
Old Apr 27, 2008 | 08:37 PM
kenthorn's Avatar
kenthorn
I think both sides dead
Old Apr 27, 2008 | 09:52 PM
bazzman1953's Avatar
bazzman1953
So what are your fuses saying for a start? Have you tested for power to the windows? Or even power to the master switch?
A multi-tester is more usefull then a socket set when doing electrical work.
Old Sep 6, 2008 | 09:14 AM
mihulka3's Avatar
mihulka3
You can get contact cleaner at Home Depot that is plastic safe. Clean the switch contacts with this. My wifes Plymouth is notorious for doing this. The cleaning helps alot. The best thing to do on American cars is to not buy a vehicle with any power windows or door locks. They use the lowest quality junk parts to assemble them.
Old Sep 6, 2008 | 12:39 PM
jimdandy's Avatar
jimdandy
Listen for the window relay clicking inside the door when you depress the window switch. You may have to get down by the door to hear it. If you hear the relay, your problem is probably mechanical, not electrical. It is a common problem for the gears to fail, especially in the older trucks. They are white plastic and crumble like bread crumbs. Kits are available at auto parts for repairs.jd
Old Sep 10, 2008 | 11:53 AM
seagull369's Avatar
seagull369
I've had problems with power windows on 2 Fords I've owned over the years. Both would occasionally get stuck in the 'up' position and not come back down. This would happen regardless of which switch (driver's or door affected) I tried. I took both motors apart & relubed 'em, it'd work for a while but the problem would reappear. What ended up working for me in the end was simply stopping the glass just a hair shy of fully closed when I 'rolled' it up. Never had another issue w/ either car after that.
Not sure if that would help u with your problem, but you might want to give it a try. You may not have to disassemble the motor to get it back down either. On my truck, sometimes it would go down when I'd flicked the switch on/ off intermittantly while driving around.
Installing a window motor usually isnt all that hard to do as long as you have some tools and can get the door panel off w/o cracking anything. The motor on my truck had a rivet I had to drill out, and a bolt I needed to hole saw through the inner door skin to access (easily anyway).
