Sponsored by: Real Truck
Noise in rear
Old Apr 27, 2008 | 12:48 PM
ibray314's Avatar
ibray314
Noise in rear
I figured out that the rear Differential bearings are smoked in the rear-end, is this common and even a better question. Are they a pain in the *** to r/r ??
Old Apr 27, 2008 | 01:01 PM
ibray314's Avatar
ibray314
Turbo Issue
On occasion when I start my truck and go to drive it you can hear the turbo spooling but it sounds like its dumping it (the truck has noooo power) and if i pull over and restart the truck numerous time's it goes away and drives great so I dont know? I need some help on this one...bad waste-gate?
Old Apr 27, 2008 | 01:43 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have you checked your intercooler boots to make sure the clamps are tight? There are 4 on the IC tubes and 2 orange ones under the spider coming out of the turbo. If they are full on grime, take them off and clean them and install them making sure the clamps are tight enough to not leak.
